Bill CNC
Dud, ... your the MAN!
It looks real good. Did you fix the rear shock mounts?
I noticed you have the three hole mounts on your shock mount. Just to be a smart ***, ... have you found ANYWHERE in the plans calling for the three hole shock mount we were TOLD to buy, or do we chalk that up to the same, "go buy more than you need so I get a kickback" mentality of the designer, like the 20 spindle brackets?
. I have them set to minimum length and still too long, I need to build a set of shorter tie rods. Tie rods I got from BMI have heim joints at both ends, that doesn't work, need yokes at the rack and pinion unit. I bought a set of yokes, but they add another 2" to the length of the tie rod.
