Silvergrizz
Well, I was hoping to have a rolling chassis by the end of today, but I didn't quite make it. Following Bill's guidelines, I only welded 1/4 to 3/8 inch at a time and waited for things to cool before progressing. :toetap05: All that stopping and starting sure makes for some UGLY welds as well.
I wasn't idle mind you, there is always grinding and cleaning to be done. However, I think my grinder is just about ready to give up the ghost. It's making some awful noise when I turn it off, and it stops real fast.
And they were just on sale 2 weeks ago for 60% off.
I knew I should have bought one or two.
Finally tackled the main suspension framing today. The A-arms and suspension halves were done on Wednesday, but I was a little reluctant to start welding the final assembly.
After checking, checking again, and a checking a few more times, (well, you get the idea) I was finally satisfied everything was square and ready to go.
Pictures of everything clamped up and ready to weld, assembly tacked, not completed yet and a shot of the suspension next to the frame. Still have to grind off 3 nuts to fit inside the a-arms for the heim joints (another great suggestion of Bill's), if the grinder holds out that is.
BTW: It;s Friday night, I'm taking the rest of the night off.
I knew I should have bought one or two.Finally tackled the main suspension framing today. The A-arms and suspension halves were done on Wednesday, but I was a little reluctant to start welding the final assembly.
I am soon going to have to hire a helper just the move it around. I figure the metal alone is over 100 lbs for the entire build before I start adding all the rest of the components.
