turbojimmy
- Messages
- 91
- Reaction score
- 0
Hi all,
We finally got our Fun Power governor linkage issue solved. It is functioning properly from a mechanical perspective, but when we operate the cart the governor is pulling the throttle shut under a load.
First, here is what we have:
It's a kart I bought used, and the Comet TC was rusty and the belt was worn. At first I thought that the problem was that the TC was not applying a load, and therefore the governor was just doing its job by not allowing me to rev the crap out of the engine with no load.
So, we changed the belt on the TC with a new one that came with a new GTC converter setup. It was a bit shorter and wider, but it really woke the kart up. It will hit its top speed now, and take off good for about 5 feet, but then fall on its face and slooowwwwly get to its top speed. Hill climbing it torturously slow but steady.
If I reach back and work the throttle manually, the thing will actually pull a wheelie and take off. So I know the TC is working. But, for some reason the governor is cutting the throttle. Any ideas? There doesn't appear to be any adjustments.
The only thing I can think of is that if you look at the pics, I am missing some linkage, but I think it's all related to the choke (which doesn't concern me). There is a rod missing that attaches to the tab I circled up to said missing linkage. In the manual it's described as the "governor-idle rod".
I know it's hitting the right top speed because wide-open, flat out, it goes just as fast as our minibike which is geared the same way (and has enough torque off the line to throw you off it - I want that on the kart).
