people heve seperated a motorcycle tranny before
but u mush be very mechanically talented and have a huge range of tools
Here are my engine Specs, http://www.tulsaenginewarehouse.com/catalog/briggs/bshoriz/350447-1079.html
From the calculator it should already be doing 52mph, I entered that it has 10" wheels tho not sure how to measure the wheels but the diameter of the wheel seems to be 10" TEETH ON AXLE is 35, teeth on clutch wheel 17, Engine RPM 3600
Are you serious? A bike is manufactured to do 200km/h. It is built to standards to be capable and not be unsafe at those speeds. A go kart, well that varies. If he gets a proper shifter kart then maybe but i still wouldnt trust it. I wouldnt trust those little spindles, tyres, 1.6mm 20mm chassis and no suspension. Hit one pot hole and your airborn and saying bye bye. A motorcycle has suspension front and rear, hydraulic brakes, fairings made to make it streamline and well do i really need to go on. A go karts made for a track where its perfectly flat, a bike is made for the road. If he takes it to a airport runway then yer but why bother. Like i said, you want to go that fast, get a car or motorcycle, those speeds just arent made for karts. If you disregard everything i say and do it anyway, good luck to you. I recommend writing up a will before hand though.hows 80+ differnt on a kart then on a bike?
How can I get my kart to do 80mph? Now it does 40, what is the best and or the easiest way to get it to do 80, Thanks.
