I have a tensioning problem with my go kart, seems the **** chain fell off again. The **** engine mount is screwed up and when I tighten the bolts down it always moves it so it changes and gets bad again. The **** sprockets are not lining up perfect so the **** chain binds and does **** when I have it anything but loose. The only way I can get it tight and good is to ****ing push the **** motor over and it goes on an angle because the **** engine mount is some cheap chinese desighn. What the hell should I do?
I'm having some trouble.
