Is governor removal necessary?
RockRon
My boys are building their cart. They "borrowed" my little Brigg engine from my Jari mower. Everything looks good, but the clutch won't lock up enough to get them moving. With the wheels raised, it spins the tires in the air. Is it because the governor is preventing the clutch from getting enough rpms to lock up? Or is it some other issue? I'm a dummy at this game.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Whats your gear ratio? it may be overloading the clutch. Is it a new clutch? it may be worn out. You dont need to remove the gov.
RockRon
I don't know the gear ratio. They bought a new clutch because they thought the old one was worn out. The new one works as well as the old one did, so I don't think it's the clutch.
devino246
Lynchburg, VA
Do this. Count the number of teeth on the clutch and the number of teeth on the axle sprocket. I also need to know the tire diameter.
JHen
Governor removal is totally unnecessary in this case. It limits max RPM reachable, usually around 3200 RPM. If it will engage with no load, then it should be engaging with a load as well, since it is only dependent on RPM.
Do what devino has said. Chances are your engine is not powerful enough to move the cart with the current tire size and gear ratio.
devino246
Lynchburg, VA
Governors on industrial engines limit rpm at 3600. These clutches are designed to work with unmodded industrial engines.
JHen
Instead of removing the governor, which creates the circumstances to blow a rod, you could modify it instead to have it allow more RPM. I haven't done this, but in theory it should work. This is also just for a 5hp B&S engine I have, I haven't looked at other engines to see how those governors work.
Basically, in the engine I have, there is a plastic gear connected to the timing gear on the cam shaft. This has two metal parts attached to it and a plastic nub on the shaft (it looks just like the one in solomon's post link). How it works is as the engine spins, it is also spinning the governor. The two metal pieces on it tilt out from centrifigal forces. This causes them to push the plastic nub piece out, which pushes on the lever inside the crank case. This lever is connected to another lever or spring or rod which is connected to the butterfly valve on the carb. When RPM's are sufficient, it will push against these mechanical bits and keep the valve from opening further, thereby limiting the RPM's attained.
Now, to increase RPM's allowed, but not remove it all together, one would only have to increase the force against the plastic nub so that higher RPM's would be needed to spin the metal pieces to create sufficient force against the plastic nub. Adding a spring somewhere that pulls back against the governor would be best. I would not do anything that would have the nub have to move farther, it could pop off and start bouncing around inside the engine.
solomon
ca
Terrible advise, no offense. The governor gear will explode past 3600 RPM. You must remove it if you want mods to work. If your afraid of the engine throwing a rod, buy an arc billet rod. and its RPM not RPM's.
JHen
Like I said, in theory heh.
meh hehe
Blazkowiez
Kart Aficionado
Houston, Texas
Yeah, you have absolutely no reason to remove the governor. This makes it dangerous for the kids in both the speed of the kart and the instability of the engine. I'd also bet once they are done with their fun you'd like to have the engine back for your mower, this means that you do not want it ruined which likely removing the governor would do.
Given that this is an older motor I'd guess its around 3hp, how heavy is the kart they've made? If the kart is amazingly heavy with rider weight the smaller engines just don't have what it takes to pull the kart around. Obviously gear ratio is a huge factor here as well, one of the best things you can do to help us help you would be to post pictures of everything including the drive wheel so we can see the factors at play.
Solomon, can you give me one good reason he should be jumping his governor for his CHILDREN's project when If he has a properly sized engine with a proper ratio the kart could be doing 35mph anyway?
solomon
ca
Like i said, its always nice for more top speed. Plus i hate the linkages to the carburetor from the throttle plate.
Holy explosions, Batman! If the governor ain't there, the flywheel explodes. If you run the engine past 3600, the governor explodes. If you eat burritos with ice cream, your bowel explodes!!!
Fack. Can somebody please point me to an exploding governor case? Mine's tweaked a little, I'm running my GX340 around 4k, no boom. Entirely stock except for tweaked governor, and homebrew muffler...
Blazkowiez
Kart Aficionado
Houston, Texas
Who in the heck mentioned an explosion. Your Honda engine can run 4500-5k likely with no problems, they are a much higher quality engines.
