Jasoninsane123
Insane Person
would bad springs cause my drive to stay open all the way when i start my kart the drive will open all the way and there goes my kart doing 10mph
Yes...
Poor maintenance and/or overloaded.
what are you calling a clutch and drive? is this a centrifugal clutch or torque converter?
hey Jason... I have heard of the parts called that also, but around hear the part that is on the engine is the ( Driver ) the big one on the jack shaft is the ( Drivin ).... oh and that rubber thing that connects the two isn't King Kongs French tickler its called the ( belt ) ..... at least thats what I was told.![]()
if its staying open its meaning its engaging, so what i would say is wrong is, your rpm engagement on you driver is really really low or your engine doesnt idle down at all! start your kart up on blocks and play with your idling screw until your wheels stop spinning. If you engine ends up stalling out because its not getting enough gas then you know that your driver has too low of an rpm engagement
so if you know what the problem is why are you asking us? lol
