Shop Our Other Brake Parts
Shop All Our Parts
Go Kart Brake Pedals
Left Side Brake Pedal for Go Karts
This great looking brake pedal is made from perforated steel. The foot pedal style can be used for brake or throttle. This pedal is a left side pedal, where the brake usually goes.
Pedal has a welded mounting shaft. Can be used for through-frame mounting.
110% Lowest Price Guaranteed!
You'll want strong, reliable pedals when building a go kart or mini bike. These pedals look great and will match perfectly. Both right and left pedals are available.
A go kart pedal on the left is used for braking, and the right pedal is used for gas.
You could also use these pedals for a brake pedal on a mini bike if you chose to. Many people use a hand brake, but a foot brake looks good and would emulate a clutch if used on the left side.
The brake pedal will hook up to brake cable, or a brake rod. If using cable, make sure that you get brake cable and not throttle cable, as the ends are different for each.
