Shop Our Other Brake Parts
Shop All Our Parts
Go Kart Brake Cable
Sheathed Cable for Brakes on Mini Bikes or Go Karts
This cable is sheathed in metal and covered by a black PVC rubber. 64 in. in total length. The housing measures 60 in. The cable has a barrel style end of 5/16in. diameter and 1/2in. long.
If you use the brake lever, this is the cable you need. The ends are the correct match, and the barrel ends are the correct match for band brakes and other brakes.
110% Lowest Price Guaranteed!
This cable is made for brake levers. This will not fit a mini bike throttle. It could be used for throttle cable if you're using a pedal and elect to cut the ends off.
The sheathed cable is very strong.
