yikes
explorer
Diesel
Robinson, Texas
OK, guess I'm in over my head,
I'm redoing a Murray go kart so I bought a Predator engine and then bought a 40 series torque converter,
got the converter today and it is longer than the shaft on the engine,
so do I just buy a long bolt to hold it on or is this a problem???
thanks for you advice
KartFab
Dallas, TX
thats what you do. Make sure you get a thick/stepped washer if the 40 series didnt come with one. use blue thread locker and either air impact the bolt on, or use a wrench/hammer to impact the bolt on.
explorer
Diesel
Robinson, Texas
yikes again
I'm trying to renew this kart that has a blown engine,
I bought a 40 series torque converter (driven) to replace the 30 shown in the pic of the jackshaft,
but......
the 40 is an inch thicker and I barely have a half inch of threads left,
what can I do??
Tpdingo
Bellmore, NY
but......
what can I do??
Buy a new jackshaft in the correct size.
https://www.gopowersports.com/5-8-threaded-jackshaft/
This a 5/8" shaft. If you have a 3/4" shaft, then you have to get a 3/4" shaft.
Tpdingo
Bellmore, NY
Both sides need threads. Your sprocket is so rust welded on that it doesn't come loose, even without the bolt.
And it is like 25-30$. That is nothing for a TAV40 swap. Make sure to get the correct size belt for the TAV40.
explorer
Diesel
Robinson, Texas
the sprocket didn't have a nut,
Is it possible to run a driven torque converter on a straight 3/4 inch shaft with no threads or nut?
how would I hold it on?
I'm having a hard time finding a jackshaft the same as mine only one inch longer,
maybe I can buy a keyed 3/4 shaft and get it threaded on both ends and buy nuts to fit
Randy H
Yes with lock collars. I did exactly that on a 420 Predator machine with a 40 series torque converter and ¾ keyed shaft. I used the elcheapo one piece variety. This works just fine, some people might feel better about split lock collars or 2 piece units.
