yet another torque converter question
azarak
central Texas
Recent (first) build was put together with a clutch in mind. However junior is having issues getting comfortable with speed and acceleration. He accelerates very slowly and only drives at about half throttle. I predict a very short life for my clutch.
I want to convert to a torque converter.
Motor is a pred 212. My understanding is a comet tav 2 series 30 should bolt on and NOT need a jackshaft of any kind. Is this correct?
Motor will eventually see some mods but I doubt ever makes more than 8-9 hp.
Also, from the picture below, do I appear to have enough room to mount one?
All help is greatly appreciated!
the Tav2 kit has the jackshaft built in correct.
And you have more than enough room, yes.
BUT:
the TC will make it worse (for a shy kid that is)
since the acceleration is much more violent (2.7 times as quick on take off) and the top speed is 10% bigger too.
So he might end up burning belts instead of clutches, and each belt costs about the same as a clutch...
Maybe you want to make another kart just for your kid.
with a much smaller engine (2.5-3 HP) that way he can get comfortable with it,
and within a few months he'll hop into your 6.5Hp kart and you're the one being scared :D
azarak
central Texas
BUT:
sounds like it would be good for me, bad for him.
the plan is to build another kart, just time and money (or lack thereof) getting in the way right now.
it did just occur to me that for about the same price of a tav kit i'm sure i could find a 3 hp motor somewhere and just swap motors when he wants to drive.
carter
I know this is an older issue, but you can put in springs that engage at a lower speed and then it'll lock up at lower revs.
