Yerfdog 42101 Carb help
Snuffalupagus
Before I torch this thing... :furious2:
Problem: Fuel pouring from overflow vent.
Precursor: Engine starts great, runs great. After 5 minutes or 30 minutes running (depending on its mood), fuel comes out of the overflow.
Preemptive strike: Rebuilt old carb with new float, needle and seat. Fail.
Primary strike: Purchased a brand new carb. Now my troubles will be gone! Nope. Fail. Same problem.
(Carb: http://www.gokazuma.com/carburetor-07-for-chinese-gy6150cc-engines-p-9502.html)
Note: New carb has a "T" on the vacuum line with the long end reaching the intake manifold and the other end being very short, about 2". Old carb didn't have the short side of the "T".
Where does the other one go and is that my issue?
Status:
Standing by with lighted match...
Please help, daughter is losing faith in Dad.
Welcome to the forum. I would have said that your preemtive strike would have solved the problem. Fuel overflow from the carb is generally due to a needle not seating properly. Are you sure that it is seating properly in your new one? Did you tear into it by any chance?
What type of engine have you got on your kart? I see the carb you got is for a Gy6 engine.
Snuffalupagus
It's the 150cc Howhit on a Yerfdog 42101.
I did remove the bowl from the new carb thinking the float was taped in place or something for shipping, but it wasn't.
We tried it again yesterday. It started right up, idled for 5 minutes with no problems. When my daughter took it out, it ran for about a minute and fuel came out of the overflow. :mad2:
Bluethunder3320
i dont really get it. the only time ive had fuel come out an overflow is because of a bad needle and seat. because thats what regulates the fuel.
does it have a fuel pump? i could possibly see that as a problem if its forcing fuel into the carb
Snuffalupagus
No, sir. No pump. It's gravity fed.
Today I connected the fuel line and before I could start it, fuel came out from the overflow.
I don't know why the float is sticking on a brand new carburetor.
:huh::confused:
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I guess it happens. Maybe you're just really unfortunate to be having this issue. I'd first try to exchange it. If not, I'd take a trip down to a mower repair shop and I'd replace the needle seat, because that's the only logical explanation in my opinion. Try blowing air with your mouth through the fuel inlet (without and gasoline of course!) and apply gentle pressure to the float to see if with minuscule force if you can cut the air off. The slightest little opening is going to allow fuel to drip.
I don't use the finger trick, too easy to push too hard. What I do is flip the carb upside down, and just let the weight of the float do it. Blow, flip, blow, flip. Do this several times with the float bowl installed- it is possible that it's not a case of a leaky valve, rather the float binding on something. Each time you invert it, it should positively change state from admitting air, to not. Don't overlook the possibility that it is not adjusted correctly, either.
Snuffalupagus
Thanks everyone for your tips.
I'm going to pull the carb off again tomorrow and see what I can do.
What's really getting my goat is how it happened on the old carb before and after the rebuild, and on the new one too.
Time for a Mikuni. :cheers2:
Snuffalupagus
Toystory, you comment about adjustment got me thinking. So, I went out today and took off the carb. I adjusted the tab that holds the needle, bending it upwards a smidgeon.
My daughter drove the kart for about an hour with no problems.
I never, ever, thought I would need to adjust the float level on an out-of-the-box, brand new, teeny tiny, Japanese carburetor.
You learn something new every day. Thanks again for all the replies!
:cheers2:
:cheers2:
Great!! Isn't it a good feeling when you get something working?
Brandon1023
needs an oil change
There's no better feeling. Especially when frustration and irritation is a precursor to your solution. There's nothing like pulling the rope on an engine in frustration, then hearing the sputtering and eventually a fluid sound of the engine running with no problems.:wai:
