Yerf-Dog Spiderbox no start
YerfJeff
Hello! I’ve recently acquired an older spiderbox that had been sitting for at least the last 10 years from what we can tell. I’ve since replaced the carb and battery. I got it drivable last Saturday. Ran great! Sunday morning I went to start it aaaaaand nothing... It barely clicked. I tried several time’s through the day and still nothing. I figured the starter solenoid was so, I ordered a new one and a new coil - just because the one on the kart was original and looked terrible.
I tested the start switch and it’s working. I also bypassed the brake switch with no luck.
What’s the next step? I haven’t shorted the solenoid, but I’d rather not. I’d bet something else is wrong.
Karts of Kaos
the many mowers guy
Wisconsin
short the solenoid it is easy and just dibble check so you don't go fixing something that does not need to be fixed
YerfJeff
Okay. I tried jumping the solenoid. Still nothing. It does have 12v from the battery. So, what am I missing here? I guess the starter is no good since it’s not grounding? It really seems like a simple circuit, but I can’t wrap my head around it.
Thanks for any advice!
Joe-405
Enjoying New Projects
U.S.A.
Just take a voltmeter or test light and see if the connection at the starter lights up with the key or from jumping the solenoid over.
Texan
Senor Member
Deep In The Heart of Texas
Same thing happened to me on a Spiderbox I worked on. I went thru all the electronics and even replaced the starter and still nothing.
The fix was taking off the blower fan cover and manually rotating the flywheel a few revolutions.
After that, it fired right up. I'm thinking the crankshaft stopped at a certain stroke position that was too much for the starter to overcome. Either that or something on the CVT was binding up.
Karttekk
Elizabeth, PA
If the kart has a GY6, 150cc engine, check the fuses in the power box on top of the engine. Doesn't take much for those to pop. Unplug and reconnect every connector in there also. Over time they oxidize and loose connectivity. Sometimes a simple disconnect and reconnect magically cures everything. Look for any melted or corroded connectors. Clean your ground wires and make sure the ground wire going to the block from the battery is clean and tight.
