Yerf-Dog Questions
kingnothing315
Greetings everyone,
A couple weeks ago I picked up a go kart fairly cheap for a project to do with my son. It needs some TLC to get it up and running.
Here is what I know..
Yerf-Dog 3206 model
Engine is a 150cc Howhit
GY6 compatible
Spiderbox assembly
Parts I replaced...
Gas Tank
Engine Wireing harness
Ignition Coil with spark plug
Voltage Rectifier Regulator
Starter Relay / Selenoid
Resistor
The current setup has an on/off toggle switch and a kill switch button. I am looking to convert it from that to a key start.
The parts listed above i purchased from BMI
Do you have any recommendations on the parts, wiring, and a wiring diagram needed to do this project?
Any advice is helpful as I am not a mechanic by any means.
Thanks, and hope I gave enough information.
Paul
Staff Murderator
All you would need is a keyed ignition start switch (like for lawn tractors) in my estimation.
