Yerf Dog- No Spark
hellfire01
Port Orchard, WA
OK I hope this is an easy one... picked up this kart yesterday pretty cheap. The guy was frustraited cause he had it running fine the day prior and now it has no spark. He was concerned because he left the battery connected but... i cant imagine that would harm anything. Any pointers would be awesome. I am going to start going over the connections but everything is pretty clean, just painted over :/
hellfire01
Port Orchard, WA
They were 2 completely different topics... ID help and elec help. One posted under general, one posted under engines. I didnt even mention ID under the engine posting...
First question: There's no spark where, At the plug or at the lead? With the spark plug removed from the engine but in the end of the lead, you won't get a spark if the plug is dead...
Also check the gap between the coil & the flywheel; it should be around 0.020" IIRC
Next question: Do you have a digital multimeter? If not, get one; if so, select the maximum ohms setting, place the neg probe on the end of the spark plug lead & the pos on the small tab on the side of the coil, where the wire to the kill switch connects. Yes, you can connect the probe to the end of the wire after disconnecting it from the switch.
The reading you get should be around 28k ohms; if it's considerable less, you could have a dead coil
hellfire01
Port Orchard, WA
Well I doooo have a multimeter, though Im not that knowledgeable on electronics when it comes to resistance, ohms, etc. I used a spark plug tester, so I removed the plug wire from the sparkplug and plugged it into the tester (one with a light) then from there to the plug which I guess is how it grounds the spark out. Anyway, no juice with the kick starter. As far as with the ignition switch, well thats not hooked up just yet and the starter is fried so I ordered a new starter. I was going to order a new coil and cdi but I couldnt find the right 4pin cdi that would fit. I need to ID the motor so I know for sure what I am working with, but the previous owner repainted the entire motor and much of the accessories in a thick layer of gray paint.
