I need help finding a replacement engine for my son's Yerf Dog gokart. It is a Tecumseh 6.5 HP 212cc enginge OHH65 71711C. The shaft length on similar engines in the 6.5 hp range are too short, which doesn't give me enough engagement with the Comet 30 torque converter. HELP !
I had that same problem, and this is what I did:
bought a 212 cc predator engine, removed the spacer from the engine shaft so it just fit as close to the engine as possible.
removed the jackshaft sprocket, and put it on the OTHER SIDE of the driven unit (eg, the outside part that touches the cam).
Its in the first post I ever put up on this site too, the last picture in the series of pics. Hope that helps, may not be the same model but will be the same solution. No need to worry about getting a longer shaft.
http://www.diygokarts.com/vb/showthread.php?t=20718
