Ok, Daughter killed 6.0 Tecumsin( broken valve keeper, bent push-rod, valve to piston...OUCH) This was due to her running wide-open when torque drive stuck in low range. So I am rebuilding it.
Finished all the welding and now to the drivetrain. I purchased a Preditor 212, after Iread some good reveiws. Now to mate it to the cart. I want to replace the clutch and torque drive( worn-out) I was told that I could not use the TAV2 system due to the shortness of the crank(2.43") vs. 3.0" on the Tecumsin. So my question is should I replace the original equipment with like items, I think it has the series 20 comet clutch and Max2 driver. My daughter is only 6 and rides on mostly level sufaces with some hills fo sand(florida). $$ is tight so want to buy only what I need. I have ben on both USA Kart and BMI. What do you all recommend.
Oh the cart is a independent front suspension with a solid rear axle(no swing arm) 2 seater (yellow) built I think in 1992. I want to build this for her to have fun with her and her freinds and maybe hang a little with the smaller 4 wheelers too.
Thanks reading this.
