Weezil
Well, nobody seemed to be familiar with the Everest brand torque converter so I thought I would start a thread and post a few thoughts and pics for your consideration.
So far it works great. No lurching at the start or sticking in the open position like the original comet. It seems to be well made (as far as I can tell) and the inside of the "bowl" where the weights ride came with dry lube applied. Comparing it side by side to the Comet, the only difference I can see is the absence of brand name stamps on the Everest, the spring being red instead of green, and the buttons being beige instead of black.
The only issue I have encountered is with the "brass" bushing that it came with. As you can see in the picture, it disintegrated. That was after only about a minute of idling and throttling with the kart on jackstands, then a 5 minute drive around the block, and a few seconds of idling in the driveway. When I went to the rear to inspect after the drive, I noticed little pieces falling out of the drive unit. Anyone encounter that before?
