Yerf Dog 3202 rebuild (Need some help and advice)
HaloJDawg
Las Vegas
I just picked up the 3202 yerf dog that needs a decent bit of refreshing.
My first question is do I need to use a torque converter or can I just use a centrifugal clutch off the engine shaft to do a direct drive?
Also, is it worth it to switch from band brakes to disc brakes?
thanks
There's a few factors in play here; tyre height & axle sprocket size for starters...
Lets say you have 17" tyres; you'll need gearing around 8:1 to avoid destroying a cent clutch in the first few minutes of driving...
If you already have a TC, clean it up & use it, you'll be much better off
Well, disc brakes are meant to be more efficient, especially hydraulic but, there is such a thing as being too efficient; for instance, my duaghters kart has a Kawasaki GPX 250 rear disc brake on it & it's geared at around 12:1 off a 3hp engine; if you do more than just touch the pedal, it'll lock up...
The other thing to consider is the difficulty of setting up such a system; I can tell you from experience, it takes a bit of messing around to get it right...
HaloJDawg
Las Vegas
Sorry for the late reply, I didn't get an email like it said I would.
I'll take pics of it all tomorrow because it's too dark now.
I don't have a torque converter at all for it, which is the main reason I was asking.
And ok, I'll just stick with the band brake for now then.
thanks guys
