Yellow jacket questions?
Andrew sharp
Kentucky
i have a few questions about my yellow jacket go kart but first i will start by telling you what i hope to do im wanting to put atv tires on it, disk breaks and a bigger axle to hold up to the rough terrain i will be riding on. however with than said how do i go about doing this the hub on my atv tires dont fit my axle on the go kart i know it will fit a yerf dog but will that fit in a yellow jacket?
also if it does would it be possible to cut the case around my axle to give more room for the bigger tires and different breaks. any help would be great.
firemanjim
Just kartin' around....
Houston Texas
Post a pic of your kart. If its the same as my yellow jacket, I'll show you what you can do. I figured out how put a 1" axle in the same tube as the 3/4" axle. And I made hubs to fit the Honda atc wheels on the 1" kart axle. If yours is the same frame, I can walk you through it. You will have to have 2 Pcs made at a machine shop though. You will need new bearing housings. Already drew up the "blueprint " cause I was gonna do this conversion till I came up with a new game plan.....
Andrew sharp
Kentucky
Here are a few pictures of it and i will be sure tontake a look at that site later on. Thank you
