Tonyzsi
I have tons of questions/issues so I'll list them all. Not sore if I should put up a different post for each or if 1 is better since they might be related.
I have a Yerf Dog 3203 with the predator 212 on it. I put installed a new jack shaft and chain on a 9 tooth jack shaft gear since I wanted quick acceleration and wasn't as concerned with top speed since I have little kids. I usually ride 1 or 2 kids around on the kart so there are 250-300 lbs. of combined rider weight.
My problem is the kart seems to accelerate ok up to ~15mph, but then it takes a while for the kart to reach a top speed of ~25 mph. On grass I'm not even sure it goes above 15-18 mph.
Do you think I need to clean the old torque converter? Could that be getting hung up until the engine slowly climbs to full rpms? Could it be something else?
I'm also having problems with the motor now that I installed the cone air filter w/ adapter. The engine has a lot of hesitation in it now that I didn't have before. I bought a #35 jet, but haven't installed it yet. Do you think that should correct my hesitation/ rough running motor?
I saw someone that had both the oil breather tube & tank breather tube connected to a plastic T that they put a mini-filter on. I found the mini-filter on Amazon for ~$5, but where can I find that T as I can see the tubes are different sizes.
I want to install a tach, but I'm not sure which one is correct as there are so many of them! I think I saw someone post that this is the correct one, but it only has 5 1/2 ft. of wire and I'd need at least 8'. Can I just crimp on another 3' or will that throw the tach off?
http://www.ebay.com/itm/Spark-Plugs...cle-Bike-MG-/181700702473?hash=item2a4e34b109
Thanks!
-T
Thanks!
-T
