As far as I understood, the Amperage is basically setting the "penetration" of the weld.
90 Amp (output!) should be enough for thinwall tubing that's used for kartframes
BUT there's a catch, those max amps are always at a very low duty cycle (mostly 10% - means, ten seconds weld, 90 secs waiting for the welder to cool down...)
So you'd want something a little higher to increase the duty cycle.. also a higher amp eases the penetration with crapier flux core wire (at least so I have been told)
So personally I picked a 130Amps flux welder (italian made TigMig TM130 to be precise) el cheapo (but comes with gas tubing in the gun.. so adding a bottle isn't really going to be expensive if needed
Can't tell how good or bad it is, since frankly.. it's still in it's box untouched...
not enough time to give it a shot.
