I have one of those Chinese Drift2 karts with a 6.5hp clone engine, which Ive run hard offroad for about 40 hours. Last week I my karting came to an abrupt halt when I noticed a large amount of oil leaking out of clutch-side of the crankcase.
When I got it home and had a look it turns out one of the bolts had snapped off and the remaining bolts were variously loose. I know Chinese "high tensile" bolts are more like mild steel so this wasnt totally unexpected. One good thing is the softness of the bolt made it easier to drill out.
I replaced all the bolts with -real- high tensile bolts and reassembled but then noticed the engine was quite a bit harder to pullstart, (as if the compression was greater than before). I hadnt pulled one of these engines apart before but I was aware of two possibilities;
1. the easy start was jammed off.
2. the timing gears have slipped with the case being loose and changed the valve timing.
After opening it up again I pulled the camshaft out to get a look at the easy start, it was worn but moves freely.
Next I replaced (put back) the camshaft making sure both gear marks were at top-dead-centre and reassembled.
Gave it a pull and all is new, started first time.
So, things I learnt that might help others:
-Replace crucial bolts, or check regularly.
-How the easy start works and how it wears.
-How the timing gears align.
-the valve system design in one of these engines (cheap and cheerful).
