r97
Measure twice cut once
Ok, so before I put my newly acquired engine in a buggy frame I want to get it in good condition first.... rebuild time! Here is the basic plan:
-Remove from motorcycle (check!)
-Disassemble engine
-Clean ALL parts
-Strip and re-paint engine cases
-Rebuild starter motor
-Replace all gaskets
-Reassemble engine
I'm hoping to avoid getting new clutch plates, or piston rings as those are pretty expensive. The stupid gasket set is already $125, and that's not even including the $99 twin carb and fuel pump kit! Piston rings will run me $130... I already need to buy paint, and lots of pipes.
Anyhow, I'm going to try and save as many gaskets as I can, and not touch the carb until I know as a fact that they do not work.
Here's some pics! Engine is a 552cc V-twin, liquid cooled, four stroke, DOHC, 4 valve, electric start, 5 speed manual, shaft drive, twin downdraft carb, 83' Yamaha!
And of course the most important tool.....
I'm noticing now that I have acquired a lot of parts! Most are from the motorcycle, and my go kart (disassembled), but not all. ATV tries and rims were scored almost new for $100!
Also some upgrades to the shop! I cleaned it up nicely, and was given a big tool chest for Christmas (how did I live without it!?). I threw in a picture of my welding cart too, just need to make the gas cylinder mounts and a welding table so I can start my build!
-Disassemble engine
-Clean ALL parts
-Reassemble engine
