ibrahim123
- Messages
- 123
- Reaction score
- 0
I have a Yamaha DT 200cc 2 stroke engine (thats what i was told when i bought it) which i will mount on my kart. Now we want to make the engine start so we cleaned the carburetor, changed the oil and what we have left is get power going to the spark. Now from the spark we know that there is a black wire going to the coil. And from that coil, we have another black wire (10cm long) connecting to another orange wire. That orange wire will go all the way to the kill switch (if thats what they call it) and from there it will go to the flywheel. Now that is the problem. We do not know which wire to connect the orange one to because we are not going to connect the kill switch to the flywheel because we do not have the switch. therefor the orange wire will connect straight to one of the wires coming from the flywheel. Now i have NO idea which wire to connect it to. If this helps ill give you the colors of the wires coming from the flywheel:
Black, Brown, White with red and white with green. Now these cables are separated
The following connect to this switch thing:
Yellow, blue and Green with White.
Thanks all
Thanks all
