Wrong output on crank shaft
GuyJ
Scotland UK
I have a honda GX200 not a clone. I got it of a old welder that packed in. The out put shaft is taperd and threaded. ive orderd my clutch witch is key way anybody know a easy way to key a shaft :( or is it a new crank for me
I believe your best bet is a new crankshaft. If there's enough material there it may be possible to get it machined to suit, but in most cases that's not very feasible or cost effective.
GuyJ
Scotland UK
Welllllllll today i was stripping down the engine took piston con rod out went to remove fly wheel (the cow boy way of the nut on the crank and give it a chap) and when i went to remove the nut discoverd the threads are nakerd :oops: tried to run a die nut down no luck :(:mad2: so might as well just get a new crank with a key. Dont know if i have a 19mm or a 20mm :S
19 or 20mm? I would imagine that if you search, you'll find that one of those is not an option. Unfortunately, I don't know which.
However, on this side of the pond, the common size is 3/4". You might do well to locate a 3/4" shaft, as there is a greater global availability of clutches and CVT's in the standard shaft size.
EDIT- Just dug up some GX200 specs. Your shaft is 20mm.
