would you do this?
buffalo47
Jemison,Alabama
New guy here. So I drug this made in China brand Taotao atk125 out of my brother-n-laws back yard and I want to install an 8hp brigs motor with a 1 inch shaft on it. The question I have is about gearing this thing. The original gears are axle=40 teeth and gear on the trans=13 teeth. It has 16x8-7 tires. it will be used on 30 acres of mostly flat field land with a couple small hills. it will be used by a 12 year old maybe 100lbs and occasionally a 170lbs adult.
thanks Jeff :cornut:
Hello and welcome.
What seams to be the problem with the original motor?
Typically it's just one of a few things. It by the looks of things a gy6 motor.
With a 8HP Briggs, you are going to have to change the gearing totally. 8hp might also be pushing it for a kart that big and wheels that tall. I would gear for at least 10:1. You will probably need a jackshaft.
I might actually be easier and cheaper to fix the engine on it
buffalo47
Jemison,Alabama
update
Thank you for the advice and reply,I have browsed this site several times in the past and you guys build some nice carts. SO here is an update. I found out that this cart was a sound running cart until the rim on the front right broke.It was garage kept but was moved around to make room for cars and other stuff eventually to the back yard.This morning I pulled plug juiced up the starter and just a click,pulled cover, chain and starter,The engine was locked. A little oil and gentle rocking back and forth it broke free. it would turn (by hand) almost a full 360 deg but stopped in both directions. pulled rocker cover and the valve adjusting plugs and you guessed it, stuck open exhaust valve. I put a little wd40 in the cylinder maybe it will free it up.
:popcorn:
buffalo47
Jemison,Alabama
Well pulled the head and was able to free up exhaust valve but it goes much deeper than that.The jug assembly has a nice rust build up about an inch before top dead center and the rings are stuck on the piston.The carburetor is also trashed up.:mad2:
By the way sorry for the "cart" reference I meant kart.:oops:
buffalo47
Jemison,Alabama
well things went from bad to worst.I spent the day honing the cylinder.cleaning the piston and ring glands and putting things back together when the cam gear snapped.I"M so mad now. i was trying to get this original engine running to save money and i was doing Good until now.starting to think the brigs motor is a better plan.:censored:
