wiring and earth
fowler
Bullsbrook West Aus
i just got a 250cc bike engine and was wondering where i ground it to
it has a ground wire going from the block to a small cylender with two screws (the solinoid i think) it also has a positive wire comeing from the other scew to the batt do i join the negative wire from the batt to the ground wire on the soliniod
sorry if the explanation is bad use the pic
Kaptain Krunch
Pro Junk Collector
vermont
No, sounds like its wired wrong. You want the negative from your battery grounding to the frame, the positive should go to one pole on the solenoid, and the other pole on the solenoid should run to the starter. block will be grounded to frame by mounting, you can ad a ground strap if you like.
Your solenoid should have two more smaller terminals on it, one to ground (earth), one that comes from your keyswitch, pushbutton, or whatever sends the "start" signal. If all it has is the two terminals you've diagrammed, that may not be the starter solenoid at all...
