Yesterday I tried welding tuna cans together for a muffler. I feel I was doing very well for how thin they are, until I forgot I needed to keep the torch straight vertical, and the wire sagged, and cut a hole into the side of the can. The fix for the hole looked incredibly ugly, having to keep the torch so far away and fighting wind/my shaky hands, so I scrapped the idea. But I was wondering if they made some type of wire extender... like out of ceramic or something, for the wire to run through to keep it stable while holding the gun farther for very little peneration... or on the other hand, they may just tend to clog up the wire running through them. I FCAW so the thing could be as simple as a tube, but I'd just worry about the wire melting/breaking in half inside of there and start piling up. Any thoughts?
This is actually starting to sound dangerous. OP- Tackweld the pieces or pulse as it is know. Thats how some car builders weld car body's together. It takes some used to, an auto darkening helmet helps the best. Also a good steady hold is key. Mount the work in a vise or a jig of some sort( a welding table w/vice and chair is about the best)whatever works, but have a space u can rest your arms so your arms/hands/body doesnt move. If u are burning through go faster with each spot (less material deposited). The angle is important. So keep it square to the face of the cans joint and short stick out like 1/2". Off square and that starts the cutting into the base metal, and it being thin well just melts through. If your going with cans and similar thin metal, raid some recycle boxes in the neighborhood go to town on them.
