Toycrusher
Measured it and I do have a 6" driven unit with the green spring.
I'm a little unclear on the speed calculations. Right now I can hit 23 mph on the gps with a death wish (No suspension, bounces like crazy on smooth asphalt and handles really squirrely, band brakes are more of a placebo than a means of slowing the cart...
I have 13.5:1 gear ratio, I'm assuming a 10% overdrive on the converter, and a briggs 5.5 rpm governed at 3600 rpm. Doing the math I should be at about 21 mph. Why the extra speed? Maybe the governor is letting the engine rev a bit more? The tires might also be growing in diameter at the higher speeds
In any case, a couple of my kids power wheels do almost 12 mph, that's a bit too slow. Maybe I'll go with a 48T sprocket instead of 60T. That drops my static reduction to 18:1, and 16.2:1 counting the overdrive for a top speed around 15 mph. The extra gearing should still help quite a bit.
As far as the electric motor, it's rated 2.25 hp, 2400 watts. Throwing those numbers into a calculator I get something between 6 lb/ft and 9 lb/ft of torqe, roughly equivalent to the 5.5hp gas engine. How to gear it becomes a big question mark.
If I used a 12T sprocket it would match engine gearing (well, minus the 3:1 torque converter "low") and should have plenty of torque, but the clutch would also be spinning at engine rpm which Tazmannusa brought up might smoke the bushing pretty quickly.
If I went with a 24t sprocket it would spin at 1/2 engine speed, probably much easier on the bushing, but I don't know if 9:1 reduction would get the big wheels moving either. Since the motor would be wired direct, no throttle controller, engaging the motor at 9:1 would be shooting for an instant 19mph! I dunno if the clutch would slip enough for a smooth and slower start, or if the chain would just pop
. Geared back at 18:1 it would only be shooting for 10mph but depending on clutch action it could still be a whiplash inducing affair...
