spongerich
I have a spare transaxle and was thinking of widening mine by using the longer axle from the spare in place of the short one.
Aside from the need to mount the transaxle offset a few inches to center everything, is there any reason anyone can think of why this wouldn't be a simple and effective way to gain some width?
On a semi-related note, I want to mount the engine and the tranny as close as possible to reduce the overall length of my kart. How much space do you think I'll need for the clutch pulleys so that I'll have enough slack/tension? It's going to be a off-roader, so I'm not looking for 50mph, but I do need to climb some fairly steep hills without slipping.
Find room. One hard bump & you could shatter your casing or, at the very least, fracture it. A pillow block only takes up 1 1/4"; it's a better alternative than rebuilding the casing
