karte_m0lim
Birds Aren't Real
Now few words about progress on TC..
This become a huge PITA ...
So in short:
- as changed clutch with TC , axle sprocket needed realigment and hitted right in chassis..
- that part of chassis is cutted out and additional bar is added to replace it.
- then sprocket hit in TC so engine should be moved forward
- then engine mount hit in chasiss and couldnt move forward so I cutted a bit from rear mount
- then, as engine was moved forward, front mount could not be fitted as rails in that spot are a bit narrower so edited that part too.
- as engine moved forward, drivet hit into seat so seat moved as well
- when you are in the seat, driver is under arm so have to make some protection, so bended 60x5 mm plate will work
- after all that finished, started engine , aplly throttle and all stuck.
- between plate and driven was too narrow so chain stuck on joint
- widen that a bit with two spacer, put all back, did a test ride and then remember that I didnt add spacer under drivet and belt is not align correctly.
- then I gave up and got drunk
- joke
So in short:
- joke
