Why do our pistons look like this >..<
sno-kart
Project was going great until today :/ just as quick recap:
We picked up a 1981 LTD 440 snowmobile for $100 off craiglist a few months back with plans to build a go kart around it. It sat outside for about 4 years straight so it needed a lot of work. We took out the motor and got to work on it. First thing we did was remove the head and cylinders to inspect everything. There was some gunk and carbon buildup which we cleaned up and then replaced the cylinder base, head, and intake gaskets amongst a few other things. After that, we had some trouble with the carbs but got everything sorted out and last week we had the engine running nicely.. everything was going great... that is until we noticed water seeping from the cylinder base gaskets on the exhaust side >..<
Today, we took everything apart and couldn't believe what we found... pistons, on the intake side, were scored... the right one actually has a flat spot on it which you can even see in the picture below. Exhaust side looked alright; just some browning which I guess is normal. Cylinders have slight scoring... there are a few spots I can feel with my fingernail... again, worse on that right hand side. We have no idea what caused this as the engine was running on 40:1 premix the whole time we were working on it and test running it.
Based on all this, what advice would you guys give us? I'm guessing pistons are beyond saving, but do we need new cylinders as well? What are the risks of putting this back together and running it? How long is it likely to work for? If things do go wrong and it seizes up, what is likely to get damaged beyond cylinders and pistons? Thanks very much.. hoping we can get past this as we just ordered all our other parts and are really excited to get this thing put together.
IMO, your premix is too weak, should be more like 25:1.
This damage is caused by friction; whether it be due to lack of lubrication, running hard, lack of cooling or all of the above; basically, too much heat.
The reason only one side is damaged is because that is the load edge, meaning there is pressure exerted against the piston as it travels up, forcing it sideways into the cylinder wall but not when it travels down.
It may be safe to reuse these parts but a bit of work is needed. Start by sanding everything with a medium grit paper (somewhere in the realm of 180 - 320). Once you remove all the scoring from the cylinders, give them a good hone.
Absolute worst case scenario is, obviously, a rebore & new pistons but, if done properly & carefully, these parts have life in them yet... apart from the rings of course...
sno-kart
Thanks Fabroman. Unfortunately, there is a note in the manual that says "cylinders in the engine are aluminum with chrome plated bores. They should not be honed or rebored."
Does this mean we are out of luck :/ New cylinders are very hard to find for this motor...
Yeah, probably :worried2:
This is probably one for the real professionals...
FatCat
2 stroke Addict!
Ottawa, IL
Based on all this, what advice would you guys give us? I'm guessing pistons are beyond saving, but do we need new cylinders as well? What are the risks of putting this back together and running it? How long is it likely to work for? If things do go wrong and it seizes up, what is likely to get damaged beyond cylinders and pistons? Thanks very much.. hoping we can get past this as we just ordered all our other parts and are really excited to get this thing put together.[/quote/]
The coolant seeping at the base gasket was your warning. You have an air leak. 40:1 is fine if your using good oil. What happened was the base gasket was leaking and allowed more air(that's not mixed with oil) into the engine. This is what caused the lean condition.
I wouldn't run those pistons unless I absolutely had no choice. There had been a lot of stress put on them. If you have a skirt break off you'll mess up the bottom end. If you can feel grooves in the cylinder with your fingernail they should probably be bored. You can have a plated cylinder bored. Its just more complex and requires you to send the cylinders to someone. It needs to be bored and then replated. If the plating isn't damaged you could possibly run it with just pistons and rings. Depends on the damage. If it can still build good compression itll run and run fine. New pistons and rings, gaskets, and DO A LEAKDOWN TEST, and you'll be set up. Leak down tests are very important. It would have warned you before this stuff happened. Those old Kawasaki's scream. I wouldn't give up on it yet. If it's too costly to replace the pistons I'd look for a whole used topend.(jugs, pistons, heads. Then add new gaskets and wrist pin clips(ALWAYS REPLACE THESE!) and you would be good to go. They will be tough to find but they made a lot of those sleds. I've got a couple local guys who deal in used parts off of old sleds. If you research and still find nothing let me know. I can drop in and see what they have.
sno-kart
Quick update and a question: we bought new pistons/rings and put the engine back together today. However, we are getting only 90 psi of compression on each cylinder. We should be seeing something closer to 120 or 130. We put plenty of oil in on the cylinders and pistons. We're pretty concerned with this reading, but it's strange that compression is low to the same degree on both cylinders. Is it normal to see low compression after putting in new pistons/rings before running the engine? Thanks!
fowler
Bullsbrook West Aus
Head gasket
Valves
A wide range of things
U should do a cylinder leakage test
It's a lot better diagnosis than a compression test
Put air into the cylinder then listen in the exhaust, intake and dip stick hole
That will tell u where the airs getting past
Kaptain Krunch
Pro Junk Collector
vermont
yeah, it should bump right up after break in. make sure you vary the throttle constantly, never hold at one position. and i like to keep it below 3/4 for the first few rides. also let it warm up before u go anywhere.
My rm250 had like 150lbs of compression before i rebuilt it, after the 4 step break process i had 180lbs
sno-kart
That's good news.. thanks guys. To fowler's point, we do want to do a leakdown test (apply about 100psi into spark plug hole with piston at TDC to see how much % it will lose over time) but I'm guessing it would only make sense to do this AFTER we break the engine in? Before we start the engine however, we will be doing a crankcase pressure test to make sure there are no air leaks. Does this sound right? Thanks.
Russ2251
AZUSA:Powered by LAWN-BOY
I never found it necessary to do this...UNLESS I suspected a problem to begin with and did happen once due to a manufacturing defect which was detected when engine was warmed up.
Always replace all seals and use correct sealants to close up the case.
I would worry that pressurizing would create a problem.
My 2¢.
sno-kart
Thanks. Is there a proper engine break in procedure for this type of motor that ya'll know about? I'd like to give the rings the best chance to seat properly so we have good compression. I know there are probably many schools of thought on how to properly break in a 2 stroke, but wanted to see some opinions. Thanks!
