whippy scooter build
Fallenleopard
N.S.W Australia
I have a 10" kids scooter which is a pretty odd size because i can't find where to get spare tires...
but i was wondering would it be worth it to put a 26cc whipper snipper on it i know it might not push me very fast but i have a nephew who i am sure would love to ride it. so yeah just wondering if its worth putting it together and if it will go fast enough to be fun?
I found an abandoned scooter last year that was quite similar to your description. I have no idea how well it worked. I tore the engine down and got it running again with a spare coil, but have been too busy with other things to reassemble the scooter. For the record, it used a friction drive system with no clutch. Just a spindle, maybe 1 1/4" that rode directly on the rear tire. As you can imagine, the tire tread was history...
Give it a go, never a bad thing to try- just don't expect a beast.
KieranM
Doin It!!
Kilkenny, Ireland
Only obstical you will have will be the shaft, they are designed for a square style "slot in" shaft, I tried something like this ages ago with a 26cc, tried everything to fit the slot and nothing worked. Yea if it all works out, it will be plenty fast, just alot of strain on the engine if there is a older user on it. Also as Toystoty mentioned friction drive is the way to go, just causes trouble with lack of grip in the wet.
Bluethunder3320
dude, when i took apart a weedeater the shaft was like square. the sprocket from the electric motor fit right on.
r97
Measure twice cut once
Massachusetts, USA
this reminds me about what i have in mind for the 25cc leaf blower engine i have, worlds best 2 stroke pencil sharpener! :roflol:, as soon as i have the time/parts sitting around... its happening!
Krustalien
Battlebot builder!
South of Spain.
I had an old electric scooter come into my reach. I took off the body work and electrical gubbings, and put on a 1.5 hp 2 stroke water pump engine.
That little engine was insane, so much torque, such a great noise.
We got to the point of (literally) ordering a clutch and going, everything was set. Throttle, brakes, custom exhaust, the whole jackshaft setup. Then it got stolen. :(
So however successful or not this might turn out to be I'd love to see one made in a similar way, like a minimoto clutch, small engine, pure fun.
Ah this is kind of off topic, my apologies.
robbie
Osceola, Missouri
I
The good news is that if the thief drives by on your bike you'll hear him.
