Which would you fix?
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Hey guys well, a new exhaust for my Subaru gx21 is 40 dollars. That may solve my problem and then ill be all good... but then again it may be some internal engine problems.
OR
I can pay 20 bucks and buy a new carb for my 5.5hp lifan gx160 clone.
I know that one is 7 horsepower, and the other one is 5.5hp but since theyre both relatively new engines they should all rev about the same so i should be able to go the same speed with either one. If this is the case then ill just put the exhaust back on the clone, order the carb and be all set.
which path should i take?
kendelrk
redneck engineer
westland michigan
josh, you can choose a cheap made hf clone, or you can pick a Subaru, i would go with the Subaru, it may cost you a bit more money, but its better to have the bigger hp. and hell, why not fix the engine that has better quality parts? do the Subaru
r97
Measure twice cut once
Massachusetts, USA
Fix the Subaru, you will have a much better quality engine, and it is 1.5hp, or about 27.27% more power. The Subaru is also governed at 4000 RPM, while the GX180 clone is governed at 3600 RPM, so you should theoretically get a slight increase of speed.
Also, don't count on the exhaust being the cause of your problems(I doubt it is). That said after seeing the picture in your other thread, you should fix the exhaust regardless to prevent it from damaging the engine.
Finally i will add that you can probably have a simple exhaust pipe made for less than $40, you might be able to make one yourself if you put some thought into it.
j.concepcion54321
East Providence RI
I think im gonna fic the clone. Its gonna be more worth it for me. If i just fix the clone, id make it look nice, repaint the exhaust with some high heat engine paint, use some engine bright degreaser on the block to make it shiny, repaint the shroud/side cover, and repaint the pullstart recoil. so that way it looks and runs nice. ill be happy with it, and that way i can save the subie for when i actually get good with engines so that i dont wreck it up in the proces of trying to find out whats wrong with it... Also in the future i plan to build like a manco dingo with suspension that would need a nice engine and a tc... the subie would fit that application perfect.
j.concepcion54321
East Providence RI
Hey I bought a go kart off of that same guy you posted above and he showed me some of his stuff. He has a few quads some running some not some just rolling frames like what you were looking for. If you want I can give you a call and ask him what he wants to do with those frames. I can ask him what he's doing with those frames if you want me to. And ill let him know that I have a friend looking for that stuff. And see if you two can't qork something out
j.concepcion54321
East Providence RI
i have the subie, a 5.5hp clone(i must add its in very bad shape, definitely beaten alot and i think the engine got dropped or something, the crankcase is bent, so is the recoil, and i think the flywheel is missing some fins.) and 2 tecumsehs. both 5 horse one is ohv the other is a flatty.
Which one will i have the least trouble with?
all the subie parts( carb, exhaust) i adapted them to the clone to get that running but.....
