Busman
Staring to cobble together a Utility vehicle for myself and the grandson to cruise around the back 40. My question is about which would be the correct torque converter to use in this application. The dimensions will be close to that of the old style John Deere Gator (just no body).
96 inches long. approx 70 inch wheelbase. 48 inches rear tread centres. With 2 adults, approx gross weight will be anywhere from 800 to 1000 lbs.
Rear wheels are 14 inch rims with 175/65R14 tires, with outside diameter of approx 22 inches. Fronts are 16 x 5.00-8.
To start off with, will be using a Honda GX390 for power because I have it kicking around.
From what I've been able to glean from the internet, you tube etc..... I would require at least a 40 series torque converter. Maybe bigger?
Also need to know what sprocket size to use on the 1 inch live axle.
I am envisioning using some sort of jack shaft for the driven pulley and then onto chain to axle.
Just to be clear this is going to be a slow moving, 10-15 mph max. utility vehicle for cruising the back acres. All flat land, no hills to climb.
Counting on the knowledge from the forum folks here to advise me on which specific torque converter ( drive and driven ), which size belt, and sprocket size to enable this buggy to move around. Attached a couple of pics for reference.
Thanks in advance.
Thanks in advance.
