Which centrifugal clutch do I need use?
Ok here goes, I am building a mini chopper, rolling chassis is complete. The engine I want to use is a 16hp, 3600rpm, 1" shaft,2-3/4" long, rear wheel is 10" X 8", tire size 205/50-10, rear sprocket is a 54 or 60 not sure because right now I am in Afghanistan and everything else is in Colorado Springs, CO. I would like to get a speed of about 45 - 50 mph. I will be home at the end of the month and would like to get all parts ordered and be there when I arrive so I can complete this project. Thanks for any help that anyone can give.
redsox985
PA
Well, a 10" tall rear tire with a 10 tooth clutch and 54 tooth rear sprocket will yield, on paper, 20 mph at 3600 RPM. A good clutch for that engine will most likely run you in the region of $100. You'll probably need a Noram brand clutch to last well with that much HP. Are you willing to pull the engine's governor to gain some more RPM? Is it a clone or a name brand engine?
panman9
looks like a clone to me. for future reference clones are generally reproductions of (usually not always) honda engines, specifically honda's gx series, they are usually lesser quality of a honda engine though.
anderkart
Surprise Arizona USA
We'll need more info to give good advice here:
First, you'll need to have someone measure the distance between the tips of 2 teeth on your rear sprocket. We just need to know if the teeth are spaced 3/8" or 1/2" apart. Then we'll know if the drive gear on your clutch needs to be a #35 or #40/41 pitch so it matches. (have them get an accurate tooth count on your rear sprocket too...)
To accurately calculate gearing we'll also need to know how many inches tall your back tire is. (I found info here:--> http://specialtytirestore.com/lowprofile.htm quoting that size is 18" tall, but have someone measure yours and confirm this)
r_chez_08
Should be in the shop...
Cornwall, UK
Hey anderkart, you're back :D
Tecnically that motor is not a copy or clone of anything. However I am pretty sure it is designed of a gx390 that is bored and maybe stroked a bit. Doesnt matter anyway unless you plan to mod.
Your tyres are 459mm diameter:
205/50-10
205= width in mm
50= sidewall height as a % of width
10= rim in "
10" = 254mm
50% of 205mm x 2 = 100% of 205 = 205mm
254+205= 459mm or 18.07" (call it 18")
Use this to find a good gear ratio
50mph and a centrifugal clutch may be pushing it. you may be better off spending double ($330) and getting a comet 40 series torque converter.
