post a pic of your TC there is no 20p3
And worse series 20 AND series 30 share a 20° cam on the driven (and the cam angle is stamped onto the cam)
So.. chances are you are reading off the cam
where the stamped cam angle (20) could end up right next to the P3 preload hole of the driven tension spring
And thus the confusion is nearly perfect!
(also: both TCs look very much alike, we need to see the inside of the sheaves to tell them apart)
One has two perfectly symmetrical Sheaves (in and out have the same slope angle)
that'd be the series 20
the Other (series 30)
has a nearly perfectly vertical inner sheave and only the outer sheave appears to have an angle
And now for the worst part the only belt that might fit a series 30 with that CtC distance is
203589A
And frankly it might be a hair too large already.. try to increase center to center distance to
6 7/8" if you can
For a series 20 TC
the belt would be a
203578A and you'd have a perfect matching belt length (it's 1/32" shorter...)
