where to get a good cheap engine
Seether038
hello all. I was given a manco go-kart model no 485-15, it has a briggs and stratton fun power 5hp engine. Runs but has issues, I was gonna buy a new engine,clutch and tires to get it going again. I am not very experienced with karts at all, could someone please point me in the direction of a quality engine for less than 200.00? thanks in advance! also, I can find lots of briggs and stratton engines online, but most do not specify if it can be used for a go kart? Thanks for any help!!
oh yeah, it is chain driven horizontal shaft..
robbie
Osceola, Missouri
What are your "issues" with the current engine? It may be cheaper and easier to deal with the problems than to replace the engine.
If you end up going with a new engine, the usual solution is to get a 6.5 hp Greyhound engine at Harbor Freight.
Seether038
the governor was removed from this engine, its a pretty fast kart..although it has some "rigged" linkage (Im assuming this has something to do with the governor removal).. Cant get the throttle to respond right when I press the accelerator, I have already adjusted the pedal..the engine has a lot of hours on it, was just gonna buy a brand new one so I wont have to work on it as much. Thanks for the reply, Im gonna check out that site
robbie
Osceola, Missouri
What does it do when you press the accelerator? If it bogs down and dies, then you're probably not getting enough fuel. You may be able to get it running right with a good cleaning.
honda-gx-power
New spark plug, carb clean and air filter cleaned its got to run a bit better.
If your buying honda gx then makesure you dont buy an engine with tappered shaft.You need a 19mm straight shaft with keyway.
Rustydog2010
NZ Nutta :|
New Zealand
'Good' and 'cheap' are not normally usually used in the same sentence.
Either you pay top money for a good quality, second hand honda. Or then there is cheap brand new chinese motors. The choice is yours.
Jeremy.
r97
Measure twice cut once
Massachusetts, USA
ewagner
Manco 485-15 need more help on replacement engine please
Our 11 yr old also has a new to him Manco 485-15 with the original Briggs 5 HP. We have tried a new carb & new plug, but it has dramatic cutoff problems with high throttle and burns oil enough that the plugs keep fouling. We want a new engine. The 6.5 HP Greyhound that is mentioned here is not available by that name, although HF does have a "Predator" 6.5 HP engine. Does anyone know about that engine? My main concern is that I want something that is a direct geometric replacement for the Briggs. I am an engineer and have replaced an engine before (on a heavy brush mower), but I don't have the resources to get too elaborate with changing the chain drive, etc. Could you guys direct us to an exact geometric replacement? Thank you so much, he really wants his kart to work.
oldbikerarlo
Old guy
Marana, Az.
The preditor 6.5 should be a good replacment with min. chain adjustment and a little throttle linkage engineering.
ARC is now making a top plate with the linkage for less tha $30 for the preditor.
ewagner
Just need a teeny bit more info please about linkage
Thank you so much for the helpful reply. I am new to go-karts and am not sure how/where to get the ARC top plate/linkage assembly that you mention. Also, is the linkage work going to be pretty straightforward? Are there any other engine/linkage set ups that would be easy and that you could recommend for us? Thank you in advance.
r_chez_08
Should be in the shop...
Cornwall, UK
I personally would buy either a clone from NR racing or a genuine honda gx160 or gx200 second hand from ebay or craigslist.
dudarino
Well I am new to go karting myself but bought the 6.5 Predator and so far has worked very well. I also did my own throttle linkage with the great help of previous posts. Just giving my opinion on the Predator.
