Where to buy these clamps?
cody89
I am going to use them to make a YZ 125 engine mount. If I have these then I can just weld the supports to them directly. Right now I don't want to spend the 200$ on the mount.
cody89
That is what I originally had mocked up. I bought some aluminum GX mounts and was going to just bolt a solid sheet of steel to it. Then weld the supports to the steel but this puts the engine a little higher then I want it because the supports are so thick.
fowler
Bullsbrook West Aus
Yeah most industrial suppliers
They make clamps like that to secure hydrolic hose
They sell them by how many hoses u want and by dia of hose
What country are u in
In Aus it would be coventrys or blackwoods
What are those ones for?
cody89
I am in the UK. The ones I have in the picture above are made of aluminum so it is hard to do anything with.
This is what I would like to try to make. Two burris clamps, then the supports welded to them.
fowler
Bullsbrook West Aus
So u just want them as spacer plates?
Or are they for mounting to a shifter kart frame
If they are for a shifter kart then go for a karting site
Or wait for anderkart to show up
He's the resident shifter kart expert
cody89
They will be for a YZ 125 engine on a shifter kart frame. Which I am using a Intrepid Storm frame.
I just need basically two steel burris clamps.
That is what i need with dimensions.
cody89
Those burris mounts wont work. I need them flat and need it to wrap around the bar instead of lay on top of it.
