Where can I get a clutch for a 10hp Tecumseh emgine
It’s a vertical shaft engine? What size is the output? Pictures of the bottom of the engine would be helpful too. The jungle store is about the cheapest. Just throw away the belt that comes with it and get a Genuine Comet belt.
Thepartsguy
If that 10hp tec is like my 12hp tec that 1 1/4 shaft will just get pulled and mulled down to a 1” then re-installed. guy could probably make a jig fire’er up lay the cutter down and go to town. Been done for a v-twin Harley engine that a local shop is building.
benclouston
1 1/4 output
Thepartsguy
1 1/4 output
JUNK if you have to use the tec pull the crank and get it milled. beware if it‘s .10 over they most likely went .10 under on the rod. That’s fine but the rods are not marked. So you would measure for stock or .10 under yourself. It’s just good info to have because your gonna rip It back down anyway when this happens. And Tecs just love to blow rods to pieces.. It’s there callsign..
