What I'm getting at... At some fixed RPM, there should be a fixed relationship between the position of the magnet and the position of the coil.
there
should be, but there will never be... it's about fixed,
but even minimal temperatur differences make miniscule differences in resistance, a temporary slight residue on the spark plug ..
and you end up with chaotic results.. predictable, but surely no precision
Are you sure about the last pic? It makes sense logically (magnet moves past coil, field collapses,...), but doesn't seem to agree with what I've come across. Maybe the trailing edge of the coil as it moves passed the first (lower) leg? The flywheel is spinning clockwise.
reasonably sure, yes!
again it's the magnetic field not the magnet.. I cannot tell at which point the field itself is weak enough to let the coilfield collapse,
even measuring it in a static manner would not tell you what exactly is going to happen, but simplified to static visual analogues... yes the last pic
you can look at the magnet's field (with a magnetic field viewer [those green film cards]) to get an idea where the field weakens off.
But really, no matter how hard you try, no matter what tool you throw at it... you will NOT get a definite result.
parts heat up, parts vibrate, coil misses to charge up to full capacity for some reason, spark plug has a temporary fuel residue, and takes a slightly higher energy to ignite...
the causes for inconsistency are plenty.
it's "about'ish" the same.. but never exactly.
(just like you cannot produce the exact same dyno result twice)
Sport cars.. well 'sporty' car engines rather removed a centralized ignition coil in favour of single coils directly attached to the individual spark plugs in order to have more consistent results.
to more accurately adjust ignition timing.
a timing light (as we all have) is just another electronical part,
when it sees the spark in the wire, it has to send the signal through it's own wire, through a solidstate switch, trigger a capacitor to discharged with aforementioned angry pixies.. they then make the lightbulb flash..
frankly.. it's just another cause for misleading readings in the end.
And that's okay... as long as there is reasonable consistency,
you can work with that as well as with accurate and precise numbers/observations
But forget about the idea that what you are observing is what happens;
persistence of view kicks your behind (that's why you need a timing light in the first place) and even IF an electric signal could travel at lightspeed (it cannot, not even close) it'd still take time for that pixie to fly from one end of a copper wire to the other...
there's no way of telling really, not with standard equipment.
a dynamic setting (set the position under strobe with a running engine) is the best you can do,
and while I know it's close to impossible to do so on a small engine,
stroberun, reset, stroberun, reset.... rinse repeat...
is still going to get you much further than thinking about how you could work that out to a static marking on the flywheel.
Once you are set to a perfect spark timing, you can mark that coil and flywheel (in respect to the engine case)..
and as long as you do not remove one or the other it'll remain a valid marking.
Now, remove both, reinstall on a different engine and you will unlikely end up with a similar result (instead you'd have to reset dynamically again)
The actual spark should cause an explosion just
after TDC,
burning rate of fuels etc... say we talk not earlier than 1° BTDC or so...
~30° at 3600rpms difference for just the pixies to fly through wires...
30° ... the magnet will not be near the coil at any rate
