wheels and tires
EBACH
va
i live in a city where there are apparently no "go kart shops":ack2:. just a couple of kiddy park tracks. where do most of you get your wheels/tires from? i'm going to be running slicks. is it hard to mount them yourself? do they require balancing?
EBACH
va
i'll have to determine the tire size once i get my rear sprocket.
EBACH
va
what size tires (slicks) do i need to run if i have a 10.25" rear sprocket??
EBACH
va
yea. thats what i was thinking. are the 12in tall tires hard to get? is that a decent racing slick size??
EBACH
va
i was going for 7:1 gear ration. but if i have to get a 72t rear sprocket, i'll have 6:1 ratio and i i'll have to deal with it. i'll run a 12 in tire, i just dont want the 12in tires to be too much for my engine.
Maybe just me, but I think you're doing it backward. Source your tires, and THEN select an appropriate gear ratio to work with them. This is especially true when you are limited in what tires you have available to you. It is much cheaper and easier to source a different sprocket...
EBACH
va
i think i'll be alright. maxxis makes a 12in tall tire.
i couldnt find a "cheap" 10t clutch anywhere. found some $250 10t clutches, but screw that mess. had to get the 12t. and i was really wanting 7:1 gear ratio for fast acceleration. just dont want my racing kart looking like a monster truck with the taller tires.
EBACH
va
how much of a difference would it be between 7:1 and 6:1?? i would like to run 11in tall tires and therefore could only fit a 72t rear sprocket. the 12's are going to look too big i think.
EBACH
va
yea gokartgalaxy.com has couple different 12in tires. and i bet some other sites do also, but i dont know them. ha! i would like to buy new, but if i find a set of used 12in, they will work.
EBACH
va
how do y'all feel about running 12in in the rear and 11in tires in the front??
EBACH
va
i got to run 12's in rear because of my 84t sprocket. so im going 12x6-6 rear and 11x6-6 fronts.
EBACH
va
and what size tubes should i buy for those size tires?? same size as the tire?
EBACH
va
not sure to buy 550 wide slicks or 600. here's a pic.
