Wheels and Tires
GoAlterBridge
I am looking for a set of two tires, wheels, and tubes. They must have the standard four bolt hole pattern, and one should preferably have a hub with 5/8" or 3/4" bearing, though it doesn't have to. the other doesn't matter hub or bearing wise, since I have them already. The tire sizes can be from 11" to 13", O.D. And hopefully, they won't have off road tread. If anyone has run across these online or have any that match these specs, please let me know. Keep in mind I am on a VERY low income, and like most people these days, don't have much cash. Thank you very much.
:thumbsup:
sayre315
Rupp enduro
Oklahoma
harborfrieght has some 5/8'' bearing wheels, tires and hubs with standard 4 hole bolt pattern for $5 ea.
kibble
I banned myself
Yeah, those aren't exactly great quality ones. They'll go to crap in seconds flat! They're made mostly for hand carts and such.
THE_REAL_RAT_FINK
Not a bad idea...
:iagree: If you do get the H.F. wheels, make sure you upgrade the bearings, change the tires, and put a new weld around the center hub.
I learned the hard way. First, the wheel cracked along the hub so I had to Weld the crap out of it until it finally got a nice bead. Next, my tires went out because they are so soft. And then the bearings started going sour. So, after all that you're probably better off finding another tire....
scar
muahahahahahaha
tractor supply has some 10 and i think 13 inch wheels dont know how good they are tho
