Wheels and hub question
leftturn66
clatskanie oregon
Hopefully here is a couple pics of my wheels and hub. Been trying to figure out what hubs to buy for these wheels as the hubs I have are cracked. Any help would be greatly appreciated! The tires are 20x11.00-9 and the wheel holes are 3/8 inch.
leftturn66
clatskanie oregon
cracked by the two set screws about two inches long and they appear to be aluminum. dont think i can weld it up strong enough being ive never tried to weld aluminum. i only have one hub also.
Ok then, that settles that.
You will need to look at 4 measurements:
1. Internal bore/axle diameter
2. Distance between stud centres
3. Diagonal measurement between stud centres
4. Stud diameter
I hope that helped.
4. Stud diameter
I hope that helped.
Yup, once you have all of those measurements, start phoning around/surfing the net for those measurements. Check all the kart sites, you should find something.
Also consider the stud holes in your rims: if they're smaller than anything you can get, ie: you have 3/8" holes but can only get hubs with 7/16" studs, you can drill out the holes. If it's the opposite, that's a bit more difficult to remedy... but not impossible
