Wheel Hubs
blade828
I'm building an offroad kart at the moment and im having trouble finding some wheel hubs. Iv'e got a 30mm axle with 6mm keyways. Ive been looking at atv wheels but i cannot find hubs to fit my axle. I found these ones that fit the wheels but obviously wont fit the axle.
Where do you guys get your wheels and hubs from?
sideways
Unfinished projects king.
Perth, Western Australia
What is the PCD of your wheels?
If you've got the skills and tools you could make your own. You can also modify trailer hubs to suit.
Otherwise, any decent go kart shop should have them. Where are you located?
Thanks
Hayden
blade828
Thought about making my own but will be hard to get everything spot on. Im in melbourne, australia. I havent got the wheels yet but the ones the ones I was looking at had 3 holes 75mm apart, or some other rims that have 3 holes 78mm apart.
sideways
Ah that's a fairly standard racing go kart size. Go to a go kart track And they will be able to point you in the right direction. If you know of any go kart shops they should have them.
Other wise, there's these. I'd ask what the PCD is first though.
http://cgi.ebay.com.au/Rear-30mm-Hub-sets-/170556642474?pt=AU_Go_Kart_Parts_Accessories&hash=item27b5f7d4aa#ht_500wt_1156
http://cgi.ebay.com.au/30mm-rear-hubs-go-kart-/200537371402?pt=AU_Go_Kart_Parts_Accessories&hash=item2eb0f5730a#ht_500wt_1156
Thanks
Hayden
blade828
Well I can get those hubs from my local go kart supplier but the bolts on them are 50mm apart, so wont fit the rims. Unless I make an adaptor so the hubs fit the different bolt pattern on the atv rims?
