david34
my sprocket bolts directly to my hub and im trying to get different wheel but i can find any that are like mine
no i wanted the wheel and hub but i dont see any like this one
in other words: you gave us no information to go by, we can't really help you unless you give us information.
You want to replace the wheel right? (at least thats what I think you want...)
Unless you bent or beat up the rim, you just need a replacement tire, is that what you're trying to say to us?
If so read the sidewall of the tire, it will have a size on it.
If you want new rim, then we still need that tire size.
If you want a new hub for that one wheel wonder then we need a bit more info.
if you want a new sprocket we need even more, different info...
clearly state your question, and give us all available information that you have, and we can help.
Okay.. I think I can see where this is going...
That's clearly a six hole Manco sprocket..
and in turn, that means it's likely a six hole manco cast spacer and a cast aluminium 5" Manco Rim we deal with here.
does that look familiar David?
Well then, let's make this short:
There is no replacement for that other than on ebay!
(if you're lucky!)
