whats the difference between the 2-212cc predator mortors at HBF
kartmonster13
whats the difference between the 2 212cc predator motors one says its certified for california and the other says its certified for all states except california im looking to get one just to throw on the mini buggy for now because there cheap untill i get a bike motor
im thinking more towards a big 4 stroke atv motor now that i have that frankenstien race cart with the trx200 motor on it that thing is crazy fast does doughnuts anytime i want it and i actually pulled a wheelie with it so that being said a 1991 trx200 motor thats been beat to almost death has that kinda power i want one in my new cart/buggy :roflol::auto::cheers2::auto::auto:
souperman000
Westlake Village, CA
its just emissions regulation that CA has...trust me, some of the laws are really strict. I think the CA approved ones have some extra wiring or something. For the emmissions like I said before.
Badot
On the blue clones the only difference was the CA model came with a much nicer screw type gas cap that sealed much better.
The predators... it looks like there's a fume recycler from the gas tank, and some really strange looking tiny muffler thingy connected to the base flange of the normal one? :huh:
Might be a ghetto evap system.
kartmonster13
how reliable are these motors really ?? my briggs fun power 5hp is a 206cc the predator motor says 212cc now i thought the 6.5 would be bigger displacement
jamyers
Buffalo Gap, TX
If the FunPower is a flathead, the extra power from the HF's additional 6cc comes from having overhead valves instead of a flathead.
kendelrk
redneck engineer
westland michigan
does the fun power run nice? if it does i beg you not to go with a predator. for the same price as the predator you can modify the fun power and it will put out much more than a stock predator
Badot
From what I've seen the HF motors are fairly reliable, especially since if they go on a gokart they're probably used a tiny fraction of the time they'd normally be used for as an industrial engine, but I have seen a lot of little, stupid problems with them -- gaskets on upside-down, bad o-rings in the petcock, just stupid little stuff not critical to the engine running, but an annoyance. If you have a Harbor Freight locally though, their return policy is pretty good.
I don't care much for the predators, not because they're bad engines but because, IIRC, they were bored and stroked, meaning they no longer take stock GX200 pistons, rods, etc. They also have only a foam element filter, and even though the engine will be run comparatively little, a gokart can kick up a enough dirt to cause concern to me.
kartmonster13
yeah the fun power runs great it has the tav 30 TC on it and its great good power and pretty good speed i just ordered a 12T sprocket from BFG in place of the 9t it had on it and
the calculator said it was at 29mph and would be at 38mph im going to replace the 16-7.5-8 carlise tires for some 20-7-8 atv tires and the dif was another 10mph so im pretty happy with that im just looking for an extra motor for the hard drive cart i have untill i find the atv/dirtbike motor im looking for...and yes its a flat head
