Whats a needle do in a carb?
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
Hey, i have a tecumseh h50 engine that only starts when sprayed with starting fluid. I have taken apart the carb and cleaned it with carb cleaner and it still wont start. One thing i did notice was that the needle didnt move up and down freely with the float... at the time i didnt think it was a big problem... and i kinda lost the thingy that held both pieces together, like a little pin to make them move together up and down... yeah that piece... I was wondering if that could be a reason that the engine wont run? does that prevent gas from getting to the engine? If thats not the problem then what do you think it could be?
Thanks,
Josh
Russ2251
AZUSA:Powered by LAWN-BOY
It's not, but without it properly functioning, you might as well be trying to start a rock.
The needle controls fuel flow and is needed.
Operates similarly to a toilet tank.
As engine demands fuel, the float will drop which in turn opens the needle allowing fuel to flow into bowl.
j.concepcion54321
East Providence RI
eh im not really interested in dumping too much money into this engine... How is the needle supposed to hook up to the float? anyone have pics so that i can see? Because it doesnt have anything currently, but on my clone carb the needle slides into a slot on the float and it stays put..... Maybe i can rig something up using the needle and float from the rebuild kit i didnt get to use.... Would that work? a clone float and needle in a tecumseh carb?
r97
Measure twice cut once
Massachusetts, USA
In the engines i have worked on..... needle attaches to float with a small pin/clip. I find it unlikely the clone needle would work. Does the rebuild kit include the required parts? is it for your model engine?
http://www.jackssmallengines.com/carb_t.cfm
Russ2251
what if i tried to run it without a needle? would it run that way?
No more than it could run without a connecting rod. Take the easy way out and do what cyborg suggested in post #3.
If you cannot handle that, then I would suggest a complete new engine. Do not touch it, and run it until it dies. Perhaps by then you will learn why things work the way they do.
