What to soak parts in?
Fallenleopard
N.S.W Australia
I am looking for a solution that can be bought in bulk like wd-40
Because the hubs are stuck on my go kart axle I have smothered it in releasing agents is there something I can let it soak in, in a bucket that will help release it
Or is there any other methods that I can use i tried pullers and a hammer but had no luck with that.
I need to reuse the hubs
Got this handy little nugget from an auto mechanic some time back:
While heat is good, thermal shock is better. Heat the frozen parts with a torch. Then immediately douse with COLD water. The rapid yet uneven contraction of the metals will break the bond faster and easier than anything else.
Naturally, you'll want to be careful around heat-sensitive materials, seals, flammables, etc.
exenos
Project Nut
I agree that the thermal shock would work great. Just heat the hub in a fire and then douse it in a bucket. Just be careful because this may make it brittle.
Bluethunder3320
find someone with a torch, heat up the hub NOT the axle. then hit it with a hammer.
the brake drums were rusted on my F-150. nothing could break them loose without breaking them. finally heated them up with a oxy acetelene torch and they came right off!
